will an e36 clutch work with an M52 and a getrag 260?
  • Spunup
    • May 2023
    • 12
    I have an m52 swapped e30 with a 260 trans and need to know if I can use the 1998 2.8 m52 clutch in it
    thanks!
  • jbontke
    • Mar 2019
    • 449
    It depends on the flywheel being used. Do you know which one you have? Additionally, M52 flywheel has an unsprung hub. If you are using a dualmass flywheel for the M52, you should be are fine. If you have a single mass flywheel, you will want a sprung hub.
    • Spunup
      • May 2023
      • 12
      thanks
