is there a wrong way to put on an eta flywheel, you know the one with the flywheel tdc pins in them. im having problems with my flywheel rubbing on the reference sensors. im trying to figure what i did wrong:(
quick question?
dont think theres a wrong way to put it in. but dont know how the R sensors get hit :s.... a quick solution would be to put a spacer (washer) between the sensor and the gearbox where it screws in. I did that same thing on my crank sensor because I had a longer sensor so used a nut in between and caught it with the screw. Hope it helps, LuckComment
dont think theres a wrong way to put it in. but dont know how the R sensors get hit :s.... a quick solution would be to put a spacer (washer) between the sensor and the gearbox where it screws in. I did that same thing on my crank sensor because I had a longer sensor so used a nut in between and caught it with the screw. Hope it helps, LucksigpicComment
