Auto transmission doesn't shift until warmed up
  • Cabrio330
    • 96
    1991 325ic. When I start the car cold, it stays in low gear until it warms up. Even shifting from D into S, 2, 1 or back will not cause it to change gear.
    Before I take it to my mechanic, any suggestions on what the problem is or how to fix it? Not 100% sure of the mileage on the car or the transmission because the PO swapped the odometer & gauges.
    Still learning my way around the E30, as I just bought this car on Monday.
    Thanks.
  • kamotors
    • Nov 2007
    • 7102
    have you tried changing the fluid or checking the level?
    7speedshop.com
    • 2002maniac
      • 4260
      Mine does this too for the first 2-3 blocks. I havent worried about it. My fluid is clean and full fwiw.
      Hopefully we can get some good input here.
      Auto = :(
      • Rolla1990
        • 199
        I believe this is normal, it helps all the fluids and gears/clutches to reach operating temperature. Every automatic car I've ever owned did this.
        Turbo M20, MSnS, 38lb, 3" no cat, RPI 12.2", ATS DTC, 240whp/240wtq, Lmnop. www.DonsGarage.net
        • ADEN
          • 620
          no no mine wasn't doing that at alll even in low temp in the morning but it did this after i did an automatic transmission rebuilt i suspect the big round pump cause it's the only used part in my rebuilt please guys check your ATF pumps.
          • 2slo4me
            • Oct 2009
            • 16
            just had the same problem... most likely its the governor inside the tranny... no bueno.
              • 37834
              lol
              Grover Beach, California
              BimmerHeads.com
              • SpecM
                • Oct 2005
                • 4531
                Mine hangs in First gear for about a quarter mile when its cold, I hate it because I have to drive at 15 or 20 mph untill it can shift... I don't want to rev the engine past 3.5g or so untill its warm too!
                tranny has new fluid and filter, and I rebuilt the front "A" clutch-basket assembly a year ago
                It's because of the seals in the valve body, when they age they leak a bit and that makes it harder for the solenoids to build enough pressure to change gears.
                1989 cirrisblau-metallic 325i
