What to look for in used differentials?
  • bmp
    • Jan 2005
    • 81
    Looking to buy used differentials and was curious what to look for when buying used ones. Wouldn't want to have it installed and find it starts humming after only 20,000 miles of use.
    Thanks.
  • Danny
    • 14216
    Make absolutely sure that they spin.
    • Adrian_Visser
      • Jun 2006
      • 2823
      make sure there is fluid in it
      jk it may be hard to tell if the output shaft bearings humm unless the diff is in the car and spinning at speed under load.
      '89 Alpine S52 with goodies
      • rThor432
        • Feb 2007
        • 3907
        If it takes 20,000 miles for a diff to start making noise, there wouldnt be a problem when you bought it.
        Best thing to do would be to pop the cover off and see what it looks like inside. You can check the backlash on the ring gear, but that's about it really. You wont get any noise out of the bearings without loading them up. If you do, dont buy that diff.
        For limited slip units you could check the break-away torque of the different output shafts to check the condition of the clutches.
        • Wh33lhop
          • 11705
          My diff whines :( I've heard that all the LSD units tend to whine. That doesn't make much sense to me but my buddy got his S4.10 rebuilt and his definitely whines (then again he has no sound deadening).
          paint sucks
          • rThor432
            • Feb 2007
            • 3907
            My limited slip units dont whine.
            • h82crash
              • 127
              The LSD is not whining, the bearings or gears are. If it makes ANY hissing noise turned by hand, it will in the car. Grab both flanges and turn as fast as u can. Also should be silky smooth, no notchyness.
              "Life is hard...it's a lot harder if you're stupid."
              Tom
              72 2002
              87 327i
              88 525i
              88 535i
              03 530i
              • Holland
                • Nov 2008
                • 7209
                Cool, nice to know.
                Originally posted by DEV0 E30
