87 BMW 325i Driveshaft Question
  • BeaLongoria
    • Apr 2009
    • 17
    I recently found a red 87 BMW 325i that needs a Driveshaft repair & I was wondering if anyone knew roughly how much this would cost.
    The car is selling for $500, so I imagine that as long as the repairs are under $1000 the car is a steal. Not sure, though. Thought I'd see what ya'll thought.
    Thanks for your time, knowledge, and attention. :D
    ---Leah
  • drift
    • 566
    Check your local used-parts warehouse or wrecking yard.
    You'll find it.
    http://www.kingofeurope.net/2010/
    • funcrew
      • Jun 2007
      • 1223
      Welcome to the forum - good to see another Las Vegas area member!
      I had my driveshaft rebuilt and installed with new u-joints, center bearing and flex disc, plus an E36 M3 shifter, all new shifter bushings, and transmission seals for around $800 or so, parts and labor. This was yet another impeccable job by http://www.e30motorwerks.com in Garden Grove. IMHO It's worth driving 5 hours each direction to have Rob work on your car rather than let anyone in Las Vegas touch it.
      Good luck!
      "If the sky were to fall tomorrow, the tall would die first."
      -Dr. Paul Forrester
      Do I LOOK like I need a psychological evaluation???
      • BeaLongoria
        • Apr 2009
        • 17
        Good luck!
        >< I'm really happy to hear that it's so cheap to get repaired, but I'm crushed that it was a 5 hour drive to get it fixed. Oh, the tow costs!
        Thanks for your information, though. =D
          If you are at all handy with tools and have jack stands (or access to same) this is a fairly simple repair. Getting the exhaust off can be a bit of a bear because the nuts will probably well rusted into place, but liberal use of PBlaster and time to penetrate will usually result in success. A rebuilt drive shaft will be in the $400-500 range.
