Shifter Refresh with Z3 1.9 Short Shift Install
  • ehrawn
    • Aug 2023
    • 235
    Short story- don’t let the internet scare you into thinking that this is a hard job. Stories of “bitch clips” haunting E30 owners seem to be wildly exaggerated.
    Since I already had my exhaust partially removed for bumper trim replacement, I went ahead and pulled the rest off, and dropped the driveline and transmission mount. Simply lowering the output end gave me plenty of room to flip the clip up and remove by hand. Part of why it was so easy was they there was basically no rubber left in any of the bushings.
    Here’s the list of parts:
    P/N Quantity Description Note
    23711175424 2 Rubber Mounting E21 Mounts
    none 4 Nylock nuts & washers Hardware store for larger trans mounts
    07129906196 1 SELF-LOCKING HEX NUT
    25111220707 1 Bearing, shifting arm
    25111220912 1 Rubber boot
    25111221849 1 Bolt
    D=10MMX40MM
    25111220600 1 Bearing, shift lever
    25117527252 1 Shift lever Z3 1.9 shift lever
    25117519669 1 Manual Transmission Shift Bushing
    None 1 Improved Selector Joint - E30, E28, E24, E36 - Garagistic
    None 1 M42 E30 318 I/IS DSSR Garagistic
    The Garagistic kit eliminates the spacers and circlips in the linkage. It’s also been updated since the online instructions were published so that you no longer need to file down the shifter- instead the mouth of the DSSR is built to Z3 width. Spacer washers are included to take out the slop of you keep the standard E30 shifter.
    That being said, this did end up being a 3 month long job. I use my local dealer for most OEM parts, assuming cost isn’t a factor. I like to create the demand directly in BMWs system in the hope that they continue to support E30s. However, it’s their policy to correct part numbers if you order something that isn’t assigned to your VIN. The E21 transmission mounts were just about impossible for them to get right.
  • pdretzka
    • Feb 2026
    • 18
    Thanks for posting this, I’ll be doing this along with a manual swap.
