i broke the sheetmetal shift assembly in my 86 325. i have to remove the driveshaft to get to it and mine has a vibration damper. i have the nuts off the dampers studs and the damper is loose but i cant remove it cuz the studs hit the tranny, and its so close i cant seem to get to the driveshaft nuts on the tranny side of the guibo with the damper there. how the hell do u get the studs out to remove the damper? or is there a way to get to the driveshaft nuts with the damper there? anyone else had this problem?
