Driveshaft Clamping Sleeve Nut Size???
  • King Tut
    • 21
    Okay I need to remove the driveshaft clamping sleeve that allows you to disconnect the front from the back. I bought an adjustable up to 38mm big arse wrench today, and it is still not big enough. What the heck size is that thing? 40mm? 42mm? I guess I will buy a wrench just to get that off.
    King Tut
    1987 BMW 325is SpecE30: spece30.ridedomain.com
    2013 Subaru BRZ: brz.ridedomain.com
    2012 Porsche Cayman R: Sold cayman.ridedomain.com
  • asubimmer
    • 6482
    vice grip size...
    • King Tut
      • 21
      Yeah I was hoping not to remove any material or destroy it with some vice grips, thanks though.
      King Tut
      • asubimmer
        • 6482
        it doesn't hurt it. I've done it plenty of times.
        • Liam
          • 753
          Oh, no.
          Some are 42 and some are 46mm don't tighten it until the drive line is fully installed and don't just slam it as far as it goes (about 35lbs torque max).
          And do you know about pre-loading the center support?
          I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
          • King Tut
            • 21
            I guess I will go get a big set of vice grips and go with that.
            King Tut
            • !kid
              • 1362
              i used a pair of channel locks you could put a rag on it if you wantto try and keep it from getting messed up
              :borg:
              • E30_fiend
                • Apr 2006
                • 7348
                its really not that tight. strong arm it with some channel locks
