driveshaft vibration
  • catchuk
    • Jan 2008
    • 344
    I just had myy driveshaft rebuilt and ballanced after installing I now get a vibration at 70 mph which I didn't before. I preloaded the csb. is it possible for that to cause a vibration? or was it just not balanced correctly.
  • Collin
    • 1736
    I was gonna say your guibo, but that would really only cause a problem when accelerating.
    Double check that the CSB is doing what it should be, and if it still is the driveshaft was balanced improperly.
    Unless you missed a nut or bolt somewhere on the driveshaft?
    My CSB came loose while driving and it was an obvious clunking noise as the driveshaft pounded itself into my floorpan. Not at any particular speed, but all the time.
    The Keystone Killers
    With 73k+ post, you'd think he'd have learned a little about life.
    • USSR2K
      • 3
      Drive shaft vibration/ Oil leak
      HI,
      I have a 1986 E30. I bought the car very cheap because it had a lot of little problems. One big problem I am having is with the driveshaft. When I bought the car the drive shaft did not have a guibo left. The guy was driving it on 3 bolts holding the driveshaft on by the heat deflector.
      I got a new guibo and put in on the car but I have a vibration that increase with speed. There is no noise when I back the car out of the garage.
      I found another driveshaft at a junk yard that was in better shape than the original one and put in on the car. However, there is still the same vibration. I can't get the car over 30 mph with all of the rear noise.
      I also have an oil leak that is not from the head casket. However it is dripping on to the manifold.
      I would appreciate anyone's thoughts or advice.
      Thanks,
      • SamE30e
        • Sep 2007
        • 4319
        Check that you phased it properly.
        1985 325e 2.8 Turbo VEMS
        • catchuk
          • Jan 2008
          • 344
          the shop painted over the factory marks and put on their own marks,
          • EricT
            • 702
            I'm getting a new driveshaft n csb...it sounds like two monkeys fucking in my driveshaft tunnel when I take off from a red light......
            BUT THIS!!!!! http://www.r3vlimited.com/board/showthread.php?t=194272
            • bimmer_E30
              • 5001
              lol^^ mine's doing the same.
              but only happens when i drive the car hard and shift hard. I only notice the vibration when first accelerating tho.
              Originally posted by e30e
              • pporcaro
                • Dec 2008
                • 327
                My driveshaft does the same thing as the OP's. Was told my U-joint is all effed up
                I wear a suit, I do coke, and I ski...:D
                That's why I drive a BMW
                • RobE30
                  • 959
                  I'm having issues w/ driveshaft vibration too. Mine seems to happen btwn 40-50 mph and is worse in 4th gear.
                  09 BMW 328xi touring 6spd
                  05 Subaru Outback XT 5spd
                  87 BMW 325is
                  a few bicycles
                  • gazellebeigem3
                    • Jun 2005
                    • 3712
                    Most of you guys posting your problems probably have worn/seized u joints.
                    Nick, after you recheck that everything is installed correctly, i would have the balance rechecked/redone.
                    • bimmer_E30
                      • 5001
                      how about the one that only happen when you shift hard and drive for a while?
                      Weird hard vibration when First Accelerating?:finger:
                      • gazellebeigem3
                        • Jun 2005
                        • 3712
                        how about your crawl under your fucking car and see whats wrong with it, instead of hypothesizing what it could be on the internet?
                        i mean what the fuck do i know anyways?
                        • catchuk
                          • Jan 2008
                          • 344
                          i reinstalled it and still have the same problem, its off to the shop again!
                          • Joe318is
                            • Sep 2005
                            • 6451
                            im wondering if these guys took the DS apart to get it in home and did not realign the two halfs when putting it back together.
                            Originally posted by vlad
                            • BakesE30
                              • Jul 2008
                              • 231
                              I had the same problem with my driveshaft, I went through 3 csb's so I decided it was time to get a remaned one from these guys--->http://www.thrashdriveshaft.com/impo...%20DRIVESHAFTS
                              Excellent service, good price and best of all no more vibrations!
