Flex disc guibo delete? Good idea?
  • e30slut
    • May 2008
    • 793
    i've seen a few e36's and such running without the flex disk. Looks kinda like they used small motor mounts or bolts with rubber washers between em...
    Have any of you done this? if so how does it feel?
    Guibos suck and I can't find one firm enough.... or cheap enough.
    the dealerships wants $75 should I go for it and call it a day or......
    lmk
  • e30slut
    • May 2008
    • 793
    no?
    • Aptyp
      • 6584
      buy one and put it in
      • Jean
        • 18228
        lmk
        Don't buy a cheap one, you'll be doing the work all over again. Buy a good quality one and it will last a LONG time if you install it properly.
        • evil_twin
          • Nov 2007
          • 2965
          pics or fail
          Paypal: vdang5@gmail.com
          Delta Auto Care
          2875-C Towerview Road
          Herndon, VA
          703.435.1375
          My Feedback Thread: Evil_Twin
          • mikegar
            • Aug 2005
            • 523
            autohausaz.com has them at an affordable price.
            Originally posted by Ferdinand
            I carry a cheap pressure gauge in my glovebox with which to manually check my tire pressures, but I keep forgetting that in the USA glovebox space is sacred as it is reserved exclusively for the purpose of storing handguns.
            DIVING BOARD DIVISION DIVISION IDIOT
            • e30slut
              • May 2008
              • 793
              Originally posted by evil_twin
              pics or fail
              I wish I took pics of it but my phone doesnt have flash
              • 87e30
                • Jul 2008
                • 5676
                How do you install one incorrectly? Face it the wrong direction?
                I just hate everyone.
                No need for discretion.
                • Jand3rson
                  • 37587
                  Just don't re-use the nylock nuts when you put the new one on. I found that out the hard way.
                  • 87e30
                    • Jul 2008
                    • 5676
                    Oh shit... I've had mine off twice and reused all the hardware both times...
                    • e30slut
                      • May 2008
                      • 793
                      oh shit... I've had mine off twice and reused all the hardware both times...
                      +1
                      • E30Idea
                        • Mar 2007
                        • 2196
                        Heading to the garage right now to r&r the hardware.
                        ** Lot's of M20 turbo parts for sale.**
                        Turn key track car.
                        http://www.r3vlimited.com/board/showthread.php?t=222066
                        • midnightslyr22
                          • Oct 2009
                          • 91
                          what are the exact specs on the bolts?
                          selling my cars
                          sigpic-BMX and Sideways vehicles-
                          Smoke tires, not meth.
                          • 3bvert
                            • 1032
                            locktite ?
                            • DJB
                              • Oct 2005
                              • 195
                              The bolts are high grade M10x50mm or 54mm (the longer bolts are used with the vibration absorber). They may be reused if not stretched or damaged.
                              The nuts are all metal self-locking with deforming metal rings around the end. They are supposed to be replaced with new each time.
                              Nuts with nylon locking rings are not suitable here.
                              I usually follow the recommendation and replace the driveline nuts with new, but have reused the old ones when I knew I would be removing them again in the near future. I always, always use a torque wrench on these bolts to get the proper pre-load.
                              Replacing the flex disk with a solid connection is idiotic. This has been covered many times -- this joint handles small-angle misalignments between the transmission and the driveshaft. Even if there is a perfect static alignment, body and mount flex will create a misalignment.
                              If you see some vendor trying to sell you a solid piece to replace the flex disk, carefully note every product they sell. Those are likely parts that you should never put on your car.
