Ok my car was sitting for 17 days and I went to drive it today and I couldn't shift into gear, ANY GEAR inc Rev.....the car inched as I was pressing against the gear (1st) but it wouldn't engage....so I let it roll down my driveway and when it was on the ground I got under it to see if there were any leaks and none....there were also no leaks inside the car around the c pedal.
I called my friend and he came over and helped me bleed the system and fluid shot from the slave as usual but now my clutch pedal has no spring and I have to bring the pedal up with my hand each time its pressed.
And like I said there is pressure as fluid is shooting from the slave....and even though I have to bring up the pedal with my hand, every time I do it i can see bubbles coming from the brake fluid res.
As far as I can see, the hard lines are secure and there are no leaks from them also and they're relatively new as of last October
I am leaning towards the CMC but I am not too sure, am I even on the right track for diagnosis? What do you all think?
Also, Does anyone have exactly the pn's of the parts I need to buy to replace the CMC and/or sc....I see on bav auto that you can buy them but I am wondering if I need to get any gaskets or anything like that or if I can use existing bolts
