So-- I'm finishing up the auto trans replacement in the wife's '88 Seta (want to get this thing done so she doesn't drive the 325is and possibly wreck it!) and had to buy new lines as the PO just cut them off below the radiator when he started to switch the trans out, so I have no idea how they ran back to trans. The question I have is do the lines run back thru the bracket on the oil pan and then thru the small space between the subframe, steering rack and motor mount? It seems that this is correct, but I'll have to disconnect the motor mount and then route them thru to the trans as it's too small otherwise and I'd like to get someone to confirm this for me.
Auto trans cooling lines routing?
