im sorry to repost, ive seen this in a few different threads, but i just finished my auto-5peed swap in my 87 325 2.7m20. i have no crank, i plugged in the auto shifter just to see if i can get crank and i got fuel pump, i did what yoshi wrote (splice 3-1 and 1-1) (if u know what im talking about) but still no crank, anyone have a good write up on how to wire up a neutral safty switch or any way around it?. my computer sucks and i cant even load some pages, pleaaaaaase someone help im so close!!
sorry
Tags: None
If you plugged in the auto shifter and can't get the engine to crank with the shifter in Park or Neutral, the problem isn't the neutral safety switch. Check the starter connections and the ground from the engine to the body.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, AL -
im guessing its either going to be that, or when i swapped pedals i think something might have popped out, i have a lose wire im going to take some pictures and hopefully get some kind of answer. i really apreciate the response!!
