Driveline Vibration between 40-65mph?
  • alpinewhite318i
    • 134
    I have a bad driveline vibration between 40-65mph in gear and neutral when on the highway. Could it be the Guibo or Center Bearing?
  • RobE30
    • 959
    ^Me too. After posting this here and BF.c, seems like the issue lies w/ the rear u-joint. Mine vibrates the worst in 4th gear, but sounds like we have the same issue.
    09 BMW 328xi touring 6spd
    05 Subaru Outback XT 5spd
    87 BMW 325is
    a few bicycles
    • alpinewhite318i
      • 134
      I have a rebuilt driveshaft that was actually rebalanced. Maybe it is just a bad driveshaft! Is your newer or original?
      • RobE30
        • 959
        As far as I know its the OE 187k driveshaft.... I haven't gotten around to getting mine rebuilt
        87 BMW 325is
        a few bicycles
        • Brandon12V
          • 1318
          dude, im getting the same crap! I had my driveshaft rebuilt at Rack&Axle with a new guibo pressed on, new u-joints, carrier bearing. Replaced the open diff for a 3.73LSD. Replaced ALL mounts for solid ones and the vibration is still there!! WTF?!
          Originally posted by Ryan...
          It now emits a beautiful blue-ish yellow/green smoke from the exhaust?? No idea what would cause that color, but I assume its good.
          • Bimmer335is
            • Jun 2006
            • 146
            I've been having the same problem as all you guys, I did the exact same stuff Brandon did... and have now gone through 2 guibos, and 1 half shaft. maybe I need a new diff.
