Thumping
  • SpeedWiz
    • Jul 2009
    • 31
    Thumping
    In first gear when i try and get on it my e30 325iC sounds like it wants the buck the diff. out. lol
    does anyone now how to fix the problem?
    That is almost always caused by a failure of the rubber mount of the CSB. Which in turn is caused by binding u-joints in the drive shaft. The fix is to replace the drive shaft and CSB. While you can replace just the CSB for a temporary fix, until the drive shaft is replaced the new CSB will have a short life.
    FYI: The drive shaft u-joints are not field replaceable. Machining is required and after the u-joints are replaced the drive shaft must be balanced. A new or reman drive shaft is the only option.
