building up the tranny for my m42 turbo build. im going to keep the getrag 240 that came with it. the engine is an m42 from a 94 318is. im going to be using a spec clutch, an m20 single mass flywheel lightened by a local shop to 16lbs. what throwout bearing will i need to use for this? is the to from the 323i correct? i feel like thats what i read somewhere, but im not sure. is there anything else ill need to consider when swaping these parts in? thanks in advance for the help!
-kevin
-kevin
