Tranny help I need some advice
  • ediaz029
    • 75
    So I just installed the 3.73 lsd I bought from here and my car still didnt run. I pulled the drain plug on the tranny and it had a full gear tooth and metal shavings on it!!!! Whats the extent of the damage? Is the tranny reparable or should I go ahead and replace or upgrade it? If so what tranny should I get? Thanks guys any help is appreciated!!
  • ediaz029
    • 75
    bump
      Geez, a bump after only 6 minutes. A little lacking in patience perhaps?
      If you found a gear tooth loose in the transmission, that one is unlikely to be worth rebuilding. Get a used transmission from a salvage yard.
      • ediaz029
        • 75
        yeah I really need to get this done what trans do you suggest 260? 240?
        • SpecM
          • Oct 2005
          • 4531
          what kind of car do you have?
          1989 cirrisblau-metallic 325i
            Right! If the car has an M20 engine, you need a Getrag 260
            • StereoInstaller1
              GAS
              • 22679
              I think you should start by getting your medications dialed in.
              Closing SOON!
              Thanks for 10 years of fun!
