I looked at Realoem.com and found it very helpful, I am still not sure what parts to order. Could someone point me in the right direction of what should be ordered.
Sloppy Shifter (yes I searched)
2,4,7,12,14 (comes with 20 in it) ,15. You want to replace all of the at once since you are in there.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
after you drop driveshaft its easy,theres a clip were mounts to tranny,not selector rod,that you have to pop up and to rear of car and slide pin out,then just c clips and cple bolts,did mine with motor out tho,akg sells a nice delrin bushing for were the arm connecting to trans, and supposed to take alot of play out,i just bought a z3 shifter,its short and amazing n cheap,50 ebay n 15 for the bushing, im gonna order 14 tho since its out and all,was debating it
Originally posted by Thehemiman View PostHow difficult is it to get in a position to replace these parts? After dropping the drive shaft and exhaust is it still going to be a painstaking task?paint sucks
The Keystone Killers: for the Commonwealth!
Member #18 of M42Club.com
1991 318is Diamantschwarz Black
1992 850i Calypso Red
