Trans Fluid Type?
  • red325i
    • 137
    Trans Fluid Type?
    Ok..ive got a '92 E30 convertible w/ a manual trans (Gertrag 260)..NO sticker on the side of the tranny...
    The BMW TIS says tranny with NO STICKER I need a ALL mineral based trans oil SAE80 API-GL-4 oil...
    or Single grade Heavy duty Mineral oil based eng oil SAE 40/30 or 20 weight
    It also says "Never fill w/synthetic engine oils or multi grade- since these oils contain coefficients of friction agents that can affect operation of the synchro mesh"
    All this being said-- WHAT OIL should i use... looking for something that i can pick up local, if possible.
  • Wh33lhop
    • 11705
    I used some Amsoil 75W90 that I had laying around for mine, make sure if it has yellow metal (brass) synchros, which it asks for GL-4 so it probably does, do NOT use GL-5. Lots of guys like Redline MT90 or MTL, but you'll probably have to order it online.
    paint sucks
    • red325i
      • 137
      I was thinking about using Royal Purple Max Gear 75W90...which is the same as the Redline MTL 90..only because I can pick it up local...
