Very short clutch engagement
  • jonmon6691
    • Aug 2009
    • 252
    Last week my clutch engagement shortened to what seems like an inch or less. It happened overnight and I haven't changed anything at all. The brake fluid reservoir is full too.
    I am using a clutch stop, but the point at which the clutch begins to engage is just above bottom where it has always been. and the clutch is not slipping as far as I can tell.
    I have no idea what would cause this or where to look, any ideas?
    <-- F*** that guy
    First I'd say to check the clutch pedal to see if something is preventing it from returning all the way. If there's nothing wrong at the pedal I'd guess on there being a problem with the pressure plate or throwout bearing.
    • Kerrath
      • Jun 2008
      • 577
      When my slave cylinder was going out, it sounds like your symptoms are similar to mine.
      • jonmon6691
        • Aug 2009
        • 252
        The pedal travel is completely normal, its just the engagement of the clutch that is short.
        <-- F*** that guy
        • blueapplesoda
          • Dec 2005
          • 1904
          stock clutch?
          • jonmon6691
            • Aug 2009
            • 252
            Originally posted by blueapplesoda
            stock clutch?
            The drive train is stock as far as I know.
            <-- F*** that guy
            • Adrian_Visser
              • Jun 2006
              • 2823
              internal leakage of the clutch slave or master cylinders. It will eventually get so bad that you cannot put it into 1st gear at a stand still with the engine running
              '89 Alpine S52 with goodies
              • jonmon6691
                • Aug 2009
                • 252
                So just replace the faulty cylinder?
                <-- F*** that guy
                • dashboardmonkey
                  FUCK YOUR WAFFLES
                  • Jun 2008
                  • 6158
                  replace them both, they have gone in and out the same amount of times
                  -Andy
                  • Kerrath
                    • Jun 2008
                    • 577
                    ^Likely, not definitely.
                    I only needed to replace my slave cylinder. Once I got under to look, it was quite obvious it was shot as it started bleeding juice when pumped. That was when it was very far gone. IIRC, when masters go bad they don't usually leak, is that correct?
                    • rede30
                      • 4697
                      I have heard of masters leaving nice puddles on the carpet. I have also had two go bad on me and both times they didn't leak. It is a good feeling to get a new master, slave and a soft line down there, all for about 100 is worth it imo.
                      • Kerrath
                        • Jun 2008
                        • 577
                        Yeah, I meant specifically e30 masters. I dont think I've ever heard of one of them leaking. They just essentially blow their rings. Lol.
                        It was worth 30 bucks for my new slave. Being able to shift with the car on FTW!
