So, my new (to me) DD is an 89 325ic. The problem I'm having is that the car shakes when I'm in gear and stopped at a light or stop sign. I haven't change the trans fluid/filter yet, but will soon. If that doesn't fix it, is there something else I can focus on or do I just have to live with this?
I've only been driving it for a few days, and I think it was sitting for a few years b/c it was running really rough and was pretty short on power at first. After a sea foam session and some fluid changes, it's doing a lot better though. A good tune up is in the works, including brakes and redoing the front end.
Something that hasn't gotten any better since the car has been woken up is the transmission though. It clunks a little when you engage a gear, could definitely be a little smoother when it shifts and sometimes seems like it's searching for gears more than it should. I'm guessing the car has around 200K miles (had 122 when the ODO stopped working in 2001). Basically, I've already accepted that sooner or later - probably sooner - it's gonna need a new trans. I'm in for the long haul though (2nd E30), so it's not a huge deal.
