I have a 87 is with a shot auto. i just bought an e36 318is which i believe has a g250, i want to use that tranny with my m20 if possible. Will it bolt up, and what driveshaft/ flywheel/PP/Clutch would i have to use? I got the e36 for 400 bucks and i want to swap the rack into my e30 and the tranny if possible and part out the rest. Thanks for any help
Can i use a g250 on my m20?
"In God we trust. All others must bring data." -W. E. Deming
/// 1987 325is /// Project Thread
Past: 87 is, 88ix, 88 i, 87 ic, 89 ix, 17 others.Tags: None -
good to know thanks alot if know one else knows ill have to try some different combos"In God we trust. All others must bring data." -W. E. Deming
Past: 87 is, 88ix, 88 i, 87 ic, 89 ix, 17 others.Comment
I was curious about this as well. My 260 is a whiner and I have a good 250. BUT what I was thinking is that it might twisted the 10deg(but the other way from the M50/g260 combo) to the left. If you have a g260/M20, it is sitting straight. G260/M50, is tilted to the right(right?). Now, put the 250 onto the M20, and now it sits left. It will require a custom tranny mount and shift-mechanism modification.-03/2005 E46 330D Touring 6spd(204hp/410nM) Sapphire Black/Naturbraun Sport...300k KM & 35mpg(mixed)Comment
