Parting
  • bsop
    • Jul 2008
    • 116
    Parting
    Im parting out my 325is, never done a parting before. Im wondering how much i can still take off the car and still be able to roll it around in the garage without much hassle. If i Pull and tranny, driveshaft and rear Diff, will the rear wheels be good to roll around?
    additionally, what is the bare minimum I would need to keep on the car in order to shove it on a trailer and bring to a scrap yard without skill sawing it to bits?
    Thanks in advance
    -Ben
  • newman
    • Mar 2007
    • 1159
    only things you need in the car is F&R subframe, trailing arms, front control arms and struts. You dont eally need springs in the car, you can use a piece of PVC or something. Leaving in the rack will make it easier to move around on your own.
    1987 325is: 495whp/400ft-lb
    UPDATED 03/12/10!: RB26DETT Swapped E30
    • FredK
      • 14761
      Yep. You can even pull the halfshafts if you'd like.
