Sloppy Second
  • Will_318i
    • Jan 2010
    • 482
    Sloppy Second
    So ever since I picked up my lovely 318... I've noticed that I have a lot of shifter play. Like I can literally shake the shifter in a complete circle while I'm in gear or neutral. So I decided to take my shift boot off and found this:
    and
    What can I do about that pretty much destroyed rubber boot? I would ultimately like a SSK, but if it's something that inexpensive and not too time consuming to do myself, I would rather do that.
    Here is how far my 2nd and 4th gears end up going. I know it normally shouldn't go this far down:
    Thanks guys.
    "get in, get off, wipe your dick off on her sheets and get out."
  • dashboardmonkey
    FUCK YOUR WAFFLES
    • Jun 2008
    • 6158
    shifter and or carrier bushings are wore out, probably both, replace them.
    not too hard of a hob just time consuming.
    not too expensive either
    -Andy
    • Wishno87
      • 6025
      Jean has a great thread on how to rebuild the early shift mechanisms.
