flywheel torque specs??
  • will61
    • 533
    im currently doing a 5 speed swap and im ready to put the 260 in but i need to know how this stuff should be torqued. Anything else that needs to be torqued to spec?
    any input would be greatly appreciated
    ::::::::::::edit:::::::::::::
    i also need pressure plate specs
    just doin track stuff :-P
    "When was the last time you drove an e30 without a smile on your face?"
  • Aptyp
    • 6584
    run to autozone/advance auto and get a Hayne's manual for torque specs
    and put blue Loctite on everything...
    • idanity
      • Jun 2006
      • 775
      install with loctite 270
      105 +-7Nm (77 +-5 ftlb)
      and star pattern should work
      but in the bentley, it shows
      1 oclock
      7 oclock
      3 oclock
      9 oclock
      5 oclock
      11 oclok
      6 oclock
      and 12 oclock for the last bolt
      as i know.
      its better to evenly tighten anything.
      so snug them up in star pattern or above pattern
      and then
      torque them up to above pattern.
      if you torque the 1st bolt up and then do the rest, by the time you get to the last bolt the 1st bolt will not be in spec.,
      bolts on by hand and evenly tightened will always be best.
      3 pedal club
      200,k+ club
      cabrio club
      port-matched- polished- purring www.BMWpark.org
      </div>
      linux since 1999
      • will61
        • 533
        thanks guys, those torque specs will work
        • will61
          • 533
          could i also have the pressure plate specs?
