So what s up with my Z3 sourced LSD?
  • a3ternus
    • 643
    Well,hello to everyone reading! :)
    I recently got the internals of a Z3 lsd installed in my 4.27 open differential but apart from the 25% lock I have no idea whatsoever about this diff.
    Can someone help me on this?
    Is it a steady 25% locking LSD?
    Is it a one or two way?
    Is it better than an E30 one?
    Whats up in general?
    N.
    Originally Posted by aaron_silva
    It is always frustrating having a harsh ride when
    you arent in the right mind set.
  • a3ternus
    • 643
    noone?
    • e30_325es
      • 1249
      Pics?
      • a3ternus
        • 643
        Originally posted by e30_325es
        Pics?
        Why would you need photos of small case diff? :p
        Anyway,the mechanic told me its a 0-25% LSD.
        Anything more anyone has to add on this?
        N.
        • SiGmA_X
          • Mar 2006
          • 287
          My bad, apparently its a torsen diff.
          :wgaf:
          PNW BMW Crew ///
          '93 325iS
          '99 528iT
          • StereoInstaller1
            GAS
            • 22679
            See, and i was told the LSD in a Z is viscous, meaning basically variable lockup.
            Less of a snap oversteer issue in the rain...but I don't know much about these.
            Closing SOON!
            Thanks for 10 years of fun!
            • guibo09
              • Dec 2008
              • 834
              alot of bad info in this thread...
              anyway, if you did get a proper Z3 diff that is infact LSD (some are open), you got a torsen diff. unless the diff came from an //M Z3, then it is clutch, same as most bmw LSDs.
              torsen LSD is very different to both clutch and viscous. google torsen, and do some research.
              90 E30 325i
              • SiGmA_X
                • Mar 2006
                • 287
                Wow good info. Are you sure of that? I wasn't aware the Z3's had a special diff. I'm still not convinced, actually, can you cite your sources?
                :wgaf:
                PNW BMW Crew ///
                '93 325iS
                '99 528iT
                • guibo09
                  • Dec 2008
                  • 834
                  yes im sure. ive just bought a torsen LSD from a z3. here is one of many sources you would have found if you did some research
                  EDIT: and bmw clutch diffs are 2-way, not 1-way
                  90 E30 325i
                  • StereoInstaller1
                    GAS
                    • 22679
                    Man up Luke! ;)
                    It would be for Kims car, mine already has LSD.
                    I really don't want her to "man up"
                    Closing SOON!
                    • kamotors
                      • Nov 2007
                      • 7102
                      yeah z3 4.27 is a torsen diff, I'm running the complete z3 diff in my car, and its a direct swap, no need to swap flanges or anything.
                      7speedshop.com
                      • StereoInstaller1
                        GAS
                        • 22679
                        Since you live in reno I am not gonna ask if it is truly different in the rain...
                        Serioulsy guys, 2 quick questions: How much safer is the Torsen style vs. clutch style
                        and
                        How can you tell them apart just by looking?
                        Closing SOON!
                        • SiGmA_X
                          • Mar 2006
                          • 287
                          Thank you. It would have been easy enough for you to post that initially :)
                          She'll be fine with either. And if not, to a skid pad she shall go!
                          :wgaf:
                          PNW BMW Crew ///
                          '93 325iS
                          '99 528iT
                          • guibo09
                            • Dec 2008
                            • 834
                            and
                            torsen is safer because it wont suddenly lock up and create an unexpected skid like a clutch diff might. it's more progressive and adaptive.
                            if you are just looking at an assembled diff... cant really tell em apart. unless you are sure it is an LSD, the torsen's axles flanges should spin opposite ways when you turn the input flange, like an open diff. clutch will spin both flanges the same way.
                            best way however is too look at the internals.
                            90 E30 325i
                            • a3ternus
                              • 643
                              So,the said LSD is a torsen 0-25% diff from a MZ3 car?
                              N.
                              PS.I just replaced the diff unit,not the whole differential.
