What diff Fits E30?
  • Funkmasta
    • May 2004
    • 7185
    What diff Fits E30?
    I am putting an S52 into an M3, and the 4.10 diff is NOT going to cut it.
    What diffs will bolt up? (E28, E24, E34, z3????)
    and anyone know of a diff that will bolt up that has between 3.2 and 3.4 LSD?
    thanks!!!!!
    Joe
    Joe Funk -- Portland Oregon
    That Guy.
    03 X5. 3 liter obviously.
  • Addissimo
    • Mar 2004
    • 1820
    the e28 535i has a 3.25... all you have to do is take the diff cover off of your 4.1 and put it on the 3.25 and it'll fit.
    Look on ebay, there are ususally a couple floating around at any given moment.
    -Addis
    Doing something M50 related? -> http://www.addissimo.com
    On Myspace? ->http://groups.myspace.com/r3vlimited
    BF2142 SN = BillyGoose
    • Jordan
      • 12913
      -Addis
      Its a bit more involved then that, but yes a e28 diff case is the same.
      The output hub stubs are different, you will have to swap the ones from a e30 diff into it. Also the cover needs to be changed.
      https://mtechniqueabs.com/
      • ed94r
        • Mar 2004
        • 382
        I started out my 3.1 s50 swap w/ an m20 trans and a 4.10. You will not be able to put the power down until 3rd gear. The 4.10 w/ stock 14" wheels(and a passenger) will smoke the tires in second gear @ 40 mph on a roll. No bs.
        I've got 15" wheels now w/ 3.73's and it's much more manageable ( and somewhat slower) but now I can put most, if not all of it down in second gear with minimal wheel spin...I recommend the 3.73 w/ the M20 trans and the 3.25 w/ the E36 trans.
        4.10 is fun and fast and some folks around my area run this set-up full time, but it really is too much gear for the street. Killer track gear tho.
        Ed
        1988 E30/S50...now with S52; Track
        1994 Miata R; ES Solo2
        1998 Lexus LX470; Wife (Slee'd anyway)
        2002 BMW 530i; A+ Commuter
        2002 BMW 325iT; Sport/Premium 5-speed
        2011 21' EconoTrailer
        • Funkmasta
          • May 2004
          • 7185
          Ed
          I was hoping for a little closer to a 3.38 (since that makes a KILLER drivetrain in an E36, I can only imagine how it would feel a couple hundred lbs lighter in an E30), but a 3.25 will do. thanks guys!
          anything closer to a 3.38 that will fit?
          That Guy.
          • Funkmasta
            • May 2004
            • 7185
            and is the E28 diff a direct bolt in (after shafts and cover have been changed) for an M3? What about an E23 7 series diff?
            That Guy.
            • BimmerToad
              • Sep 2004
              • 1537
              Ed
              Keep the 4.10 in the back with a 260. 5th gear 260 is an overdrive gear 0.81:1, and 0.81 X 4.10 = 3.32 final ratio. An E36 tranny has a fith gear of 1:1, so 1x3.25 = 3.25
              A 4.10 and a 260 is closer to the gearing set up E36 M3 guys want for the track (3.38 )
              On 2nd thought, I don't know if a 260 is capable of handling S52 torque :?
              San Diego BMW repair -> Jake @ www.littlecarshop.com Great guy :up:
              • Funkmasta
                • May 2004
                • 7185
                we are using the ZF E36 M3 transmission...
                That Guy.
                • nickmp0wer
                  • 1427
                  damn joe, are u going to be keeping this car?
                  • Funkmasta
                    • May 2004
                    • 7185
                    No :( its not mine.
                    That Guy.
                    • Screaming_bmwe30
                      • 128
                      Ed
                      First off...it's not the 5th gear drivablity they are talking about....they don't want super short 1, 2, 3 gears with the amount of tourque it's gonna be putting down. Second of all..your calculations/speculations must have nothing to do with anything besides how long 5th gear is....because an e36 with a with a 3.25 rear end will top out ENORMOUSLY faster than an M20 with 4.10's....use common senser here.
                      Secondly...S52's aren't that torquey at all. A 260 tranny can easily handle over 300whp and 300ft-lbs....using slicks....launching at 6000k rpms. Just ask bimmerjim :) I'm putting out way more than an S52 on 10psi....and the 260 is holding up just fine. Bimmerjim's ride is more of a testemant to the duribility of the 260 gearbox though.
                      • equate975
                        • Jun 2004
                        • 3382
                        Yeah this was for my car, im putting the diff in now, What do I do to change the axle stubs? More specifially what are the torque specs?
                        Rollin' with a Geistkuchen
                        • DanGillan
                          • Mar 2004
                          • 4061
                          there's no torque spec, the output flanges just slide in and out, use a pry bar if nececarry to take the old one's out, and a light mallet to get the new ones in if you need it.
                          Dan
                          • AdamF 88iS
                            • 2051
                            E24 diffs will work too, but like Jordan said you'll have to play with flanges and covers to get it in.
                            Z3 diffs ar a direct bolt in.
                            E32/34 diffs will not work.
                            Adam Fogg- '88 M3
                            Common sense- It's the new 'gifted'
                            • Matt86es
                              • Aug 2004
                              • 616
                              There is also a 3.43 from an E28, i think.
