I'm currently asking myself if the drain plug and the filler plug are the same part numbers ?!?!? Are they ?
Question about differential plugs...
BMW E30 325i 1991
Mods:
MarkD Chip
aFe filter
E36 M3 Bushing kitTags: None -
Difficult to say. They look alike, but nowhere I found the proper specification. The only hint I found is that you can buy the drain plug. I presume both are the same.BMW E30 325i 1991
Mods:
MarkD Chip
aFe filter
E36 M3 Bushing kitComment
They are the same plug. There is an updated part with a new type of sealing surface.
Rear diff parts
33-11-1-210-405 Diff cover gasket $2.65/2.25
33-11-1-206-166 Speed sensor o-ring, 27.1x22.3x2.4mm $0.69/0.59
1" x 3/32"
62-16-1-369-905 Diff speed sensor to 9/87, 2 flat pins 'T' shape, all white
62-16-8-355-008 Speed sensor magnetic switch 9/87+, 2 round pins, black ring
61-13-1-372-396 2 pos connector shell, 'T' configuration, speedo? $1.05/$0.79
61-13-1-362-252 Connector, female 6.3mmx22.3mm, correct size for '396?
33-11-1-212-682 Diff drain and fill plugs, superseded by 33-11-7-525-064
33-11-7-525-064 Screw plug w/ring, M22X1.5-ZNS3, for diff 2@ $3.30/$2.81
07-11-9-963-355 A22x27mm-Al crush washers, 2@ $0.26/0.22
33-12-1-200-284 Differential input seal dust plate $1.90/$1.62
33-10-1-214-099 Diff input (pinion) shaft seal, 45x75x10
33-11-1-214-144 Rear axle bearing carrier o-ring 90x3mm $2.00/$1.70
33-13-1-208-006 Rear axle output flange dust plate 60x84x5 2@$1.16/$0.99
33-10-7-505-602 Rear axle seal with lock ring 67x44x10 $11.80/10.03
33-13-1-214-100 Obsolete number for non-step 44x67x10mm seal, 31-50-7-510-831?
33-21-1-225-893 Axle shaft w/ ABS wheel
33-21-1-226-901 Axle shaft w/ ABS reluctor
33-21-9-067-810 Outer CV boot kit $56.38/42.28 $11.82 AutoAZ
33-21-9-067-812 Inner CV boot kit 68.07/51.05
GKN Loebro picture shows locktite, 6 bolts, grease + boot/band/circlip/plate
33-21-9-067-814 Inner CV boot kit, alternate part? 58.35/43.76
Inner boot kit has 1 band, circlip, metal ringed boot and backing plate
33-21-9-067-815 Outer CV boot kit, e30 and z3 $50.52/37.89
BMW outer boot kit includes all 3 bands, circlip and grease
EMPI kit includes only 2 bands, circlip and 118g of grease
GKN Loebro kit includes 0 bands
33-41-1-124-945 Rear axle nut lock plate 0.68/0.51
33-41-1-125-664 Rear axle collar nut M22x1.5mm 7.28/5.46 2.93
33-41-1-132-565 Rear axle nut M24x1.5mm for e36, not e30 or z3 7.28/5.46 4.12Comment
Thanks for this tremendous information. Unfortunately, this new updated part is a pain in the !$&. You need this 15mm Allen key that is almost impossible to find.BMW E30 325i 1991
Mods:
MarkD Chip
aFe filter
