tranny swap question
  • canbedirtye30
    • May 2007
    • 9
    I really surf here alot and can usally find the answers without posting..but I cant seem to find these answers..
    can I use the auto brake booster? if not what is different on the manual
    can I use the mastercylinder off the auto as well? I only ask because it appears you can simply snap the nipple off then use it with a clamp..it looks like its squeezed shut..no other differences I could find???
    I thank you for all the help as Im in the middle of this swap on a 325ic I just picked up...
    The brake booster, master cylinder, and reservoir for manual & automatic transmissions are the same. The clutch fluid nipple on the reservoir is sealed shut and has to have the sealed end cut off.
    • canbedirtye30
      • May 2007
      • 9
      thank you for the info....its much appreciated..
