Did a clutch job, reinstalling driveshaft, 1" gap?
  • the spyder
    • 62
    Hey guys,
    I am putting together the e30 I got (with no transmission/clutch installed). Its together, runs (which is great), but I have hit a strange spot. When I went to install the driveshaft, I could not get it close enough to the guibo/flex disc! There is a 1" gap. I loosened the center bearing, pulled, and it does not want to slide forward. Is there a trick to this? Do I need to jack up the diff or loosen something else?
    Thanks!
  • Todd Black 88
    • Oct 2007
    • 3449
    wrong D/S for the tranny? Was the car an auto originally, and now a stick or?
    Originally posted by codyep3
    I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
    2001 silver/Blk 325 cabby. SOLD
    2002 325xit Sil/blk. SOLD
    2010 F650gs twin
      It is very common for the dust/water seal under the drive shaft gland nut to disintegrate with time and almost lock the drive shaft halves. The best fix is to separate the drive shaft halves, throughly clean the splines, lube with chassis grease and reassemble with a new seal. This can be done with the drive shaft in the car, but it is a lot easier with the drive shaft removed.
      As Todd Black 88 suggested, might it be that you have an auto drive shaft?
      • the spyder
        • 62
        The driveshaft is a 5spd, and is to my knowledge org to the car.
        I will check what you suggest jlevie, thanks!
        • DJB
          • Oct 2005
          • 195
          Mark the driveshaft before separating.
          When rejoining match the marks, and then try one spline off in each direction to verify that you have the correct spline to exactly align the U-joints. It's easiest to reassemble removed from the car so that you can check the U-joint against the floor rather than using a short bubble level.
