Cheapskate method of making a clutch line...
  • ChaseN
    • 709
    Hey guys
    I'm in the middle of a 5-speed swap on my iX, and, well, I just realized tonight that the ONLY part I haven't bought yet is the line between the master and slave cylinders. So, I cruise on over to RealOEM, plug the part number into Tischer's website, and HOLY SH!T they want $60 for a freaking HOSE, that will take an unknown amount of time to get (thats my only gripe about getbmwparts.com really, that you can't tell whats in stock and what isn't).
    So, I got to thinking...its really only a brake line, the hard part of which I could bend myself using pre-flared brakeline from autozone (I already have the hardline coming from the master out the firewall) with a flex portion to compensate for the different movements between the transmission & body. So I think, where can I find cheap flex line? I log onto Jeg's and find 10" SS braided flex hose, and its only $9.99, and ships tomorrow from Ohio (which is obviously very close to where I live). Only problem is its female to female -03AN. SO, a quick click on adapters finds me -03AN to M10x1.0 adapters for $9.99/pair. SUCCESS!
    Basically, I just wanted to run this by the members here and see if it won't work for some reason. I don't see why it wouldn't. To sum it up, it would be (in order from master cylinder to slave cylinder):
    stock hardline through firewall
    adapter to -03AN
    10" -03AN flex hose
    adapter back to M10x1.0
    Autozone pre-flared M10x1.0 hardline to slave cylinder
    All for less than $20, and I know it will be here by Wednesday. Beats ~$60 and unknown arrival time.
    What say you all? I know its a lot of adapters and what not, but with mostly new hardware I'm not really worried about leaks.
    Chase
    1991 318iS
    1992 911
    2006 330i 6-Spd ZSP people hauler
    Gone:
    1989 M3 S50B32, 6-Spd
    1990 325ix 5-Spd
  • Conrad311
    • Oct 2009
    • 370
    did something similar on mine last month and so far so good (knock on wood)
    bleeding it out sucked ass though.. it took forever with out a vac. bleeder or a press bleeder.
    good luck with it
    "In God we trust. All others must bring data." -W. E. Deming
    /// 1987 325is /// Project Thread
    Past: 87 is, 88ix, 88 i, 87 ic, 89 ix, 17 others.
    • ChaseN
      • 709
      good luck with it
      Luckily, I have a Motive pressure bleeder. Plus, from my experience on my S50B32 swap, even the BMW OEM components take FOREVERRRR to bleed.
      Good to hear I'm not the only one doing this.
      1991 318iS
      1992 911
      Gone:
      1990 325ix 5-Spd
        • 37834
        Seems like it should work fine. I'd go OEM but that's just me.
        Grover Beach, California
        BimmerHeads.com
          Get a used line from a salvage yard.
          • FredK
            • 14764
            A new one at AutohausAZ is $28, though it'll take a while to get it. You can call Bav Auto in New Hampshire and have them price match it.
            Besides, Jegs has a handling fee according to your order size.
            • ChaseN
              • 709
              Wow, thanks. Ended up just ordering one of these.
              1991 318iS
              1992 911
              Gone:
              1990 325ix 5-Spd
              • Mossman
                • Apr 2006
                • 1961
                Yeah only problem with this plan is the stock line has a hardline section on the end with a bend to get it out of the way so you can access the 13mm nuts that hold slave to tranny with a socket and extension. But yeah new is cheap and I don't think stainless will offer any change in clutch feel like it may with breaks, and 4 more places to leak is bad news.
                You made zee right choice chase!
                • DJB
                  • Oct 2005
                  • 195
                  The clutch line is under less peak pressure than brake lines, but otherwise it's constructed exactly the same. You can just assemble two off-the-shelf M10 hard lines with a M10 F-to-F hose -- either a generic length or the ones used for the rear subframe. (The front and rear wheel hoses are M-to-F.)
                  • SpecM
                    • Oct 2005
                    • 4531
                    thats exactly what I'm doing
                    got an inner rear brake hose, and a 8in section of hard line
                    costs less than $10
                    1989 cirrisblau-metallic 325i
