Quick, simple shift linkage questions
  • Jand3rson
    • 37587
    Does the '86 325eS have the sheet metal console, or the aluminum shift carrier? If so, can the sheet metal console be swapped to the aluminum shift carrier?
    I would assume the later-style carrier is a better unit than the early-metal console, hence the redesign.
  • James Crivellone
    Head Janitor
    • 6305
    if the car is built AFTER 04/86 then it has the aluminum
    if before, then its sheet metal.
    Either one can be used depending on transmission, some have the mounts for the sheet metal, some only have aluminum mounts, and some have both (mine)
    My tranny is from an 87 eta 4 door (i think) and it has both sets of mounts
    • Jand3rson
      • 37587
      Well, my car is 01/86, so I guess it has the sheet metal. Is the aluminum shift carrier preferable to have?
      • James Crivellone
        Head Janitor
        • 6305
        I pefer the aluminum, easier to work with imho, and you can do a little work from the top to work on things if you have to
        • kencopperwheat
          King of Kegstands
          • 14396
          The sheet metal one wasn't too bad to work with, in my opinion. If you drop the driveshaft out it'd be MUCH easier to work with though.
          Originally posted by Gruelius
          • Bryson
            • 1490
            i have a friend who converted his 89 325is to the sheetmetal type because it is stronger, he kept breaking shift carriers
            • Jand3rson
              • 37587
              Ha ha ha, damn! Ok then, I'll keep that in mind. :D
              • kencopperwheat
                King of Kegstands
                • 14396
                When/if you rebuild the shift linkage, you could replace the rear bushing (the big fat rubber thing) with something more solid. Also, if you take the selector rod off and place a piece of urethane or derelin in where the foam/rubber piece goes it'll stiffen the shifting up a ton.
                • Jand3rson
                  • 37587
                  Cool, thanks for the tips, Ken. I do in fact plan to rebuild the linkage and those things should be good to stiffen things up. I probably won't tackle that job at least until I put in a new driveshaft.
                  • kencopperwheat
                    King of Kegstands
                    • 14396
                    Yeah, definitely do it while you have the driveshaft out... it'll make things a lot easier.
                    • Jand3rson
                      • 37587
                      James, what are the best ways to reduce slop in the shift lever with the sheet metal console?
                      • Drewe30e
                        • Apr 2005
                        • 171
                        My transmission is acting oddly and I would like to replace anything pertaining to the shifter or shift linkage. I will be doing the Z4 2.5 switch along with this. I saw the thread in the FAQ's and I was wondering if all the parts mentioned for the sheet metal console will be what I need. Or, will I need to get more parts?
                        1985 325e - 5000 RPM's of Fury
                        • fretburnr
                          • Jan 2005
                          • 1496
                          can it be done while replacing the guibo? (that should disconnect the driveshaft, eh?)
                          Jay
