What kind of diff comes in an 89 325ic auto?
  • monzon
    • 252
    I tried to look around it, but didn't see any tags or markings I recognized.
    88 M3 - 95 E320 Wagon - 70 Mini - 04 LS430
    BBS RS-style wheels for your RC car:
    http://www.teampogi.com
    http://www.facebook.com/teampogi
  • F34R
    sLaughter
    • 12376
    My Brothers '89 vert is a 4.10 LSD
    In the future jack up the rearend and see if both wheels turn the same way. If they do you have a LSD, if not a STD. And STDs SUCK!!!
    Now, mark the tire from the tread down 2" and the slide under and mark the drive shaft.
    Have a friend remember where the mark was and have him turn the tire one full turn 360*
    While you are on the ground counting how many times the chalk on the shaft goes 360*
    So he turns the wheel one rotation and the shaft goes 3.5 rotations, you have a 3.46LSD on your hands.
    Ratios:
    http://en.wikipedia.org/wiki/BMW_3_Series_(E30)
    Hope this helps
    ~Brandon
    Instagram: @BWeissLeather
    Current cars:
    ~ '87 325 M30B35 swap
    ~ '87 535
    ~ 01 540 Msport 6spd
    ~ '06 X5 4.8is
    • monzon
      • 252
      Thanks! Never thought of that method to figure out the ratio, but I'll give it a shot.
      • F34R
        sLaughter
        • 12376
        You are welcome, you can also read the tag on the rearend. Most of the time they are ate away and useless.
        Current cars:
        ~ '87 535
        ~ '06 X5 4.8is
        • lateracer
          • Sep 2009
          • 302
          my 89 vert has a 4.10 open (standard, normal, lame...all are good descriptors). It also has a small tag on the diff cover with 410 on it.
          If you're lucky, yours will have 373s (3.73 limited slip). Chances are it doesn't though.
