shifting issues?? help...
  • custom e30
    • Nov 2009
    • 347
    i broke my shift arm, i have replaced it, i put everything back together 3 time because of this issue, so here it is,
    i will take off in first, the SYNCHRONIZER are chattering a bit, and then alot depending on where im putting pressure on the shifter at?, when i shift to second, i cant get to second unless its chattering its ass of, but once I'm in second i can make it stop chattering by pushing the shifter top the right side while still in second,
    if i go to down shift its touching and chattering,
    its always difficult to get into reverse.
    like i said Ive double checked everything out of the Bentley book 3 times and its all right, but there is something off somewhere or out of line that is causing this,
    PLEASE HELP.....
