Blew slave cylinder again
  • 89325iturbo
    • Mar 2004
    • 723
    Went to install another slave cylinder in my car, and it ennded up popping apart again. This time i did not touch it outside the car.
    Installed it and bleed it. After doing the process a few times of bleeding. Was pumping the petal to get some pressure there i heard it pop and saw the fluid coming out of the bottom of the transmission.
    No it cant be the slave cylinder this is the third one. the others i thought maybe i didnt bleed right, but this one i did.
    So something else must be wrong causing the slave to break. Theres no leaks from anywhere, but the clutch master cylinder sounds like its pushing fluid and air around. Almost like a gurgling sound when im done pumping it. And the fluid in the resovior gets little air bubbles in it.
    Just dont know what to do.
    If the slave cylinder popped apart when mounted to the bell housing, either you have the wrong slave cylinder or there's a problem inside the bell housing.
