I put in a new CSB after the last one began the dreaded squeaking noise, slapped the new one in, and now I have a bad vibration under hard acceleration, as well as at anything over 50 mph. The driveshaft did not cause a vibration before I pulled it out (which makes me rule out an out-of-balance driveshaft). It gets worse when I let off the gas. I made sure to properly preload the CSB when I put the new one in, the guibo/engine mounts are only 6 months old, all of the bolts are tight, etc. I also made sure the two halves of the driveshaft were lined up with eachother as they were when I pulled it out.
I read that it may be the "splined sleeve collar nut" which keeps the two pieces of the driveshaft connected - if you over tighten this nut, it can bind and not allow the driveshaft to move in and out. This is something I plan on checking out but if any of you guys have some advice, I will try that as well.
Let me know
-Joel
Let me know
-Joel
