I had my car up on stands to replace the guibo when I found all sorts of fun stuff. The previous owner had replaced the transmission and did about the worst job anyone could do. One of the mounting tabs for the transmission is completely broken off and he tried to make his own mounts out of this really gummy rubber. No good. The guibo was installed with 5 bolts of different kinds (instead of 6) and 4 nuts. (On the positive side it was easy to change because the rest of the nuts were already loose!) The CSB was completely destroyed and he GLUED it back together! By the way, part of the negotiation of the sale was for him to replace the CSB, which he obviously did not do. Not to mention all the shields and bolts that I removed to get at the driveline were all finger tight.
My questions are:
-How do I post pictures on here?
-How do I secure the transmission with a broken mount?
-Should I get a new CSB or a new/rebuilt driveshaft? I have no idea how to tell if the u-joints are good
-Are there any other areas that would be affected by the p.o.s P.O. driving the car like this for a long time? Diff mounts? Subframe mounts?
My questions are:
