I had a blast running my e30 at the track today until my clutch started slipping! I pulled into the pits and looked under the car and gear lube was steadily dripping out of my bellhousing! I changed the input seal about 2000 miles ago when I did my M50 swap, but I cant think of anything else that would cause this, can you? I had to leave the car at the track and am picking it up tomorrow. Also if it is the input seal do you think I can just clean my clutch disc and other parts with brake clean and re-use them or am I buying another clutch?
Thanks
Thanks
