starter nut stuck inside gearbox!!!!
  • agustingig
    • Dec 2009
    • 140
    Well replacing my starter today, my buddy dropped the nut that holds it down inside the gearbox (where the flywheel and clutch is.. is there a way to get this out without pulling the engine back out and gearbox of the back?? Quick answers please am going to pull the motor first thing in the morning if theres nothing else.. :sad::sad::sad::sad::sad:
  • dashboardmonkey
    FUCK YOUR WAFFLES
    • Jun 2008
    • 6158
    access cover? long magnet?
    -Andy
      You might be able to fish it out through the starter port. The trick, unless you have a borescope, is figuring out where it is in the bell housing. Unless it got caught between the flywheel and engine, it should drop out if you separate the engine and transmission.
      • whodwho
        • Jun 2008
        • 1547
        Originally posted by agustingig
        ...am going to pull the motor first thing in the morning if theres nothing else..
        If it comes down to it, it is easier to pull the transmission then the engine??
        My M20 Frankenbuild(s)
        4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
          You probably don't have to completely remove the transmission to get the nut out. Unbolt it and slide it back an inch and you should be able to get the nut out. So yes that would be easier than pulling the engine.
          • whodwho
            • Jun 2008
            • 1547
            Depending on the miles on the clutch, if I had it that far out I would pull it all the way and at least inspect the clutch, pilot bearing, TO bearing, and replace that plastic pivot tit.
            • agustingig
              • Dec 2009
              • 140
              Everything is new,, i havent turned the motor over since it went in,, im gonna try with the magnet like someone said here above,,
