bought a 97 M3 S52, Im in the process of a swap and wnat to know what tranny i have. Are there markings on the transmission that will tell me this, or did the cars only come with certain transmission for specific years?
Transmission woes
Since one tends not to hear of lots of problems with E36 transmissions, I'd say they are comparable to a Getrag. Keep in mind that 5th on the ZF is 1:1 where the Getrag 260 is .82:1, so to keep engine revs reasonable at highway speeds you need a lower ratio differential. Say something around 3.15.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
Yeah i've been reading about the diffs and it seems like the 3.25 LSD is the way to go. I have a 89 325i vert I'm doing the engine and trannyswap into, but I'm not sure what diff ad tranny are in it right now. Are there any markings on the diff ad tranny in the 325i i could look for?1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IPComment
well im pretty sure im gonna stick with the M3 transmission, and just change the diff. 3750 at 70 just doesnt sound all that fun. What else is salvageable or worth swapping from the e36 to the e30? People recommend 5 lug swap but that seems to be about it.1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IPComment
