Oil In Bellhousing
  • Gus
    • Jan 2004
    • 285
    Oil In Bellhousing
    just replacing my clutch...got everything out but have discovered that my bellhousing has an awful lot of oil in it....which would have been causing clutch slip! im thinking that its the rear main crank shaft seal leaking....any other suggestions? not exactly a situation i like to be in...
    JUNGL3
    1990 "333i" Sport
  • Jordan
    • 12916
    rear main seal, and transmission input shaft seal are the most likely causes.
    However it is not uncommon for the valve cover gasket/doghouses to leak oil down in.
    If its alot of oil its likey the rear main seal. Is it engine oil for sure? or tranny oil?
    https://mtechniqueabs.com/
    • Gus
      • Jan 2004
      • 285
      99% sure that it is engine oil, clutch disc is saturated in it. may as well
      replace both those two seals.....just need to wait till tomorrow and hope
      dealer is open! damn easter. fairly certain it isnt coming down from the cam
      cover either. also hope to do your shift carrier brass bushing idea whilst im
      here
      JUNGL3
      1990 "333i" Sport
      • BS87
        • 1606
        Hey jordan, when you remove the piece that holds the rear main seal, you don't have to drain the oil, thats only on the 4 cylinders, right?
        • Jordan
          • 12916
          I'm actualy not sure. You will spill some oil, but the vast majority of it will drain away to the front sump of the engine.
          • devarato
            • Mar 2004
            • 66
            http://www.bimmersport.co.nz/forums/...c=3235&hl=[/url]
            • AdamF 88iS
              • 2051
              The trans can also leak from the shaft plug below the input shaft. The problem is that you can't get this plug out unless you rip the whole tranny apart. It looks like you can if you take the circlip out, but let me save you some time, you can't. All you can do is fill that dip where the plug is with some epoxy to seal it shut.
              Adam Fogg- '88 M3
              Common sense- It's the new 'gifted'
              • Gus
                • Jan 2004
                • 285
                is definately engine oil.......g box oil is very clean....got replaced anyway....
                now just waiting for BMW to open again after easter.....damn
                JUNGL3
                1990 "333i" Sport
