Rear Tranny Seal Leaking
  • BimmerHeadBri
    • Oct 2004
    • 48
    The rear of my tranny is leaking pretty bad. I have a bunch of stuff to do under there anyhow, (guibo, driveshaft support bearing, ssk) so I should do this at the same time.
    Has anyone done this themselves before or is it a shop job? Do I need any special tools to change the seal?
    Also, does someone have the part numbers to order, I just cannot seem to find them on my ETK.
    Thanks.
    BimmerheadBri
    '86 325 (eta)
  • Jordan
    • 12916
    Yeah, its pretty easy to change. You will need a thin wall socket to remove the output flange bolt. I forget what size it is exactly, but i want to say 32mm.
    https://mtechniqueabs.com/
    • James Crivellone
      Head Janitor
      • 6305
      Its a 30mm Deep thinwall socket
      • Jand3rson
        • 37587
        Cool, I need to do this as well. Good to know.
        • BS87
          • 1606
          the Thin walled 30mm socket is a pain in the ass to find.
          • Jordan
            • 12916
            I have the socket Josh.
            • Jand3rson
              • 37587
              Excellent. Since we'll be swapping out the output flange, the seal shouldn't be too much more work. :D
              Jordan be da man. :up: Now, to think of something to repay him for his soon-to-be generosity...
              • BimmerHeadBri
                • Oct 2004
                • 48
                Has anyone in Canada had any luck finding a 30 mm thin .....
                Anyone in Canada have any luck finding a thin walled 30 mm socket? If not, where in the U.S. have you guys found them?
                Thanks.
                BimmerheadBri
                '86 325 (eta)
                • Jand3rson
                  • 37587
                  Re: Has anyone in Canada had any luck finding a 30 mm thin .
                  Thanks.
                  Do you guys have Sears there? If so, I'm sure the tool department could order you one, if they don't already have it. If not, try some auto repair shops, and see if you can get one from their Snap-On rep (or whatever distributor they use).
                  • Jordan
                    • 12916
                    You don't just "find" a thin wall socket in this size.
                    You get a normal impact socket, and grind down the face.
                    • BS87
                      • 1606
                      Snap on makes a 30mm thin walled deep socket. Good luck finding a truck that has one with them, though.
                      • BimmerHeadBri
                        • Oct 2004
                        • 48
                        Yeah, we have Sears and Snap-On reps as well. I will check around. Jordan said just grind down the face. Pardon my ignorance, but you mean grind down the outside of the socket until it fits? Sounds like more work than changing the tranny seal. ;)
                        Thanks guys, I will look around. If I do happen to come across some commercially, I will let you know.
                        Cheers.
                        BimmerheadBri
                        '86 325 (eta)
                        • BimmerHeadBri
                          • Oct 2004
                          • 48
                          Rear Tranny Seal Leak - Any other parts I need?
                          I was just reviewing the posts on this and noticed a couple of guys mentioned changing the output flange... could that be what is leaking as well?
                          I would just hate to pull all this apart, change the seal only to find that the flange is the cause or part of the cause of the leak.
                          Anyone??
                          Thanks.
                          BimmerheadBri
                          '86 325 (eta)
                          • Jordan
                            • 12916
                            The output flange doesnt leak. The rear seal seals against it, and that is what leaks.
                            Replace the seal, its like $3. Find a socket at some auto or home tool store, grind it down and be done with it.
                            • BimmerHeadBri
                              • Oct 2004
                              • 48
                              Thanks Jordan
                              Thanks Jordan. That will be next week's project.
                              I also finally got the parts for my z4 3.0 short shifter. So while I am under there, I plan to change the guibo, center support bearing, tranny mounts, and the shifter and all the shift bushings.
                              Should be a busy weekend.
                              Thanks.
                              What do people like for tranny fluid? Redline?
                              BimmerheadBri
                              '86 325 (eta)
