Slight rattle noise
  • E30Gus
    • Jun 2008
    • 781
    Slight rattle noise
    OK so I am hearing a slight rattle noise with the clutch disengaged in neutral. The noise goes away when the clutch is depressed. It's not a real loud sound but am wondering what it could be. Everything in that whole area is new except the actual transmission.
    I have a track day coming up and don't want to be stranded or miss out on any track time.
    Thanks,
    G
  • E30Gus
    • Jun 2008
    • 781
    "While the noise could be from the throwout of pilot bearing, that would be unlikely with new parts. A more credible cause would be rattle of the transmission input shaft. Unless really bad that's not harmful. " Jlevie
    I hope in my searches I found the answer ^ (from JLevie again)
    Is it possible to put the pilot bearing in too far? And would this make a rattle sound?
      • 37832
      No the pilot bearing should be all the way in the hole.
      Probably just the "Getrag rattle".
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • E30Gus
        • Jun 2008
        • 781
        Very cool!
        Thanks
