grinding noise, clutch? starter?
  • ///digitalme
    • Dec 2009
    • 2088
    so i was driving last night and all of a sudden i start hearing this grinding noise when i would give the car some gas...i first thought i fucked my engine, but after some inspection engine is fine..the noise seems to be coming from the transmission part..but i couldnt hear it from outside i closed my doors and windows and i give it some gas and you can hear something grinding against each other when the transmission is in neutral...heres a video of it being on neutral...what can i check to see whats causing this grinding? maybe flywheel? starter? clutch itself?
  • ///digitalme
    • Dec 2009
    • 2088
    nvm
