4.10 swap
  • M5W
    • Aug 2009
    • 134
    4.10 swap
    Hi guys. Doing an s38 into my 86 325es, which has a 2.93 lsd right now-to long. I have a 4.10 lsd from an e34 535i auto in an e34 case on the shelf from my e34 days. I have a friend with a small case 4.10 lsd from his 318is. Can I out my 4.10 medium case internals into my buddy's small case ? I just wanna swap the lsd unit, not the center shaft that connects to the driveshaft. Since the small case is a 4.10 already I assume it would match up ? And can I even fit it inside the small case ?
  • Danny
    • 14217
    I'm pretty sure you cannot do that.
    Wait for someone to confirm though.
    • Wh33lhop
      • 11705
      Even if you can, I would not do that. A small case behind an S38 will not last long.
      paint sucks
      • M5W
        • Aug 2009
        • 134
        This idea is on hold for now. Gunna get the car running on the 2.93 and see.
        • xwill112x
          • Jan 2009
          • 4237
          wont work. small cased is to small for medium cased diff stuff.
          • Stu
            • 4083
            No, but you can put the E34 typ 188 ring and pinion into your existing 325es 188 housing.
