Is 75w-90 fine in a getrag 260?
  • Schwarz325
    • Aug 2009
    • 487
    My trans didn't have a label on it, so found online that it's either atf or gear oil, so i drained my fluid and it was nothing like ATF, so i tossed some mobil 1 synthetic gear oil, 75w-90? I talked to a guy at at shop here he said anything but somekinda bmw fluid is gonna blow every bearing out?
    what say you?
  • drumad
    • Aug 2009
    • 1700
    Someone confirm this. If the synchros are made out of brass you want to avoid using any API GL-5 gear oil. The more "advanced" formula of GL-5 vs GL-4 will destroy the brass synchros.
    I ran into this problem with my Nissan when I accidentally filled it with the same Mobil 1 75w-90 (GL-5). I didnt run it bc I looked into it more and realized I needed GL-4.
    GL-4 75w-90 gear oil is sorta hard to come by but all you need to Redline MT-90 which is exactly that. Because of the MT-90, its like shifting through butter.
    Then again, the 260 might be a bit more "advanced" than my nissan tranny.
    edit:
    GL-4 is a must. Redline MT-90 is the way to go it seems. The Mobil 1 will destroy the tranny components.
    2008 335i - n54b30
    1991 318i - m52b28
    1994 fzj80 - LAND CRUSHER
    • Schwarz325
      • Aug 2009
      • 487
      THanks alot buddy, i appreciate it! Looks like i'm gonna be draining it out.
      • long tall eta
        • Jul 2010
        • 1536
        what about lubro-moly 75/90 synthetic?
          A Getrag 260 wants ATF or Redline MTL.
          • george graves
            • 19993
            What about an e30 m3 Getrag 265?
            Originally posted by Matt-B
            • Gesucht
              • Nov 2009
              • 100
                • 37828
                Whoa guys, run of the mill 75w90 is FINE in a 260 transmission, unless it has an ATF label.
                Don't waste money on $30 in fluid. Don't want to listen to me? Fine.
                Classic BMW Specialists
                Grover Beach, CA
                www.BimmerHeads.com
                • Schwarz325
                  • Aug 2009
                  • 487
                  so what i put in that thing is fine?
                  if redline MTL is 75-90, which is what it says on the bottle? why the hell can i not use the mobil 1? pretty much the same shit
                  • Schwarz325
                    • Aug 2009
                    • 487
                    and i believe it says gl4 and 5
                    edit: i'd have to check the bottle in the garage
