What bushings do I need to eliminate shifter play?
  • unrlmth
    • 467
    Right now I have a ton of play in my shifter (im pretty sure everything is original with 205k). What parts do I need to replace to get it to feel a little better? Also if I wanted to go with a slightly shorter throw, whats the easiest way to do that?
    1989 325i Alpineweiß II
    What bushings? All of the them. There are a lot of way to go w/respect to an SSK, but I'm rather partial to the ones from AutoSolutions.
    • Charley
      • 396
      BluntTech E30 Short Shift Kit:
      This is what I bought haven't tried it yet since the car is still in the air.
      Also replacing the seals on the transmission is a good idea I had ordered
      mine at the same time and I'm glad i did...
      edit:I also changed the gear shift rod joint...
      Charles
      • F34R
        sLaughter
        • 12376
        Call up Rob, he will hook you up with poly bushings and washers. I love mine SO MUCH!!!
        Instagram: @BWeissLeather
        Current cars:
        ~ '87 325 M30B35 swap
        ~ '87 535
        ~ 01 540 Msport 6spd
        ~ '06 X5 4.8is
