1/2 -1 inch lateral play in driveshaft when pushed, pulled. CSB?
  • txtorquemade
    • 1758
    From under the car, up on jacks and ramps, I push the driveshaft side to side (latereally) and theres about an inch of play. It actually moves that much.
    When I accelerate from a stop, I frequently get a thumping behind and between the front seats, from the tranny tunnel. Or so that is how it sounds. I also have heard a howling from the rear worse when turning right, so Im thinking thats a L rear wheel bearing.
    Is this the CSB? U joints look ok from what I can see, except 1 of the 4 bolts that attach the rear ujoint of the DS to the diff flange is gone. The play in the driveshaft seems to confirm CSB for the thumping. I think.
    Ideas anyone?
    Thanks...
    sigpic 1987 325is
  • Teaguer
    • Sep 2004
    • 6167
    Yes that points directly at a bad CSB.
    How are you able to pull on the d-shaft and not see the csb though?
    Is your heatshield still installed or not?
    • txtorquemade
      • 1758
      Heat shield still there Teager, and I cant see shit. But it moves when I push against it about and inch. I wonder is the missing diff flange bolt the cause, or do I need new ujoint and or DS also?
      Looks like the guibo has a crack as well.
      BTW Teager, know anyone good for doing an install on the guibo, CSB, trans output seal and diff seal?
      sigpic 1987 325is
      • KVF
        • 297
        You could also get side to side play if the retaining bolts for the CSB mounting bracket are loose. This obviously comes to mind because you mention missing a bolt at the rear end as well. Having just done my complete drive-line I can say it's not that tough of a diy. At the very least I'd pull the shield, replace the lost bolts/nuts and make sure everything is properly tightened to see if that fixes the issue. Good luck.
        • txtorquemade
          • 1758
          That sounds reasonbable. Problem is I cant get under the car well with my current jack and stands/ ramp. If I had a lift no doubt it would be very doable. Might just have to take to an Indy mech.
          But man I hate to for sure. So I might try your advice first. Maybe to the guibo CSB.
          sigpic 1987 325is
          • M-technik-3
            • 18946
            make your own ramps out of 2x8's.
            • evilnickwong
              • Aug 2007
              • 302
              I had the exact same thumping sound from between the seats which sounded like it was right under the handbrake console.
              It turned out to be the CSB, and subsequently a bad driveshaft. Not sure if driving around with the driveshaft thumping caused it to go bad or if it was already bad in the first place, but I ended up replacing both. :D
              • txtorquemade
                • 1758
                Yeah.. Im really not wanting to hear new drive shaft, but ..... ugh!!
                sigpic 1987 325is
                • txtorquemade
                  • 1758
                  Got any schematics for that lil build?
                  Srsly!!
                  sigpic 1987 325is
