Hello, I recently bought a 325is with a bad u joint. I bought a used driveshaft and discovered the center bearing doesnt line up to the original center bearing bolt holes.
The car drives great with the new shaft however I was only able to thread 1 bolt through the center bearing. Should I drill a new hole to hold the bearing in place?
The original center bearing was round, the bearing that came with the new shaft is oval.
Thanks alot!
Thanks alot!
