Noises past 30mph
  • NC325iC
    • Mar 2004
    • 6565
    Noises past 30mph
    Ive done a bit of searching and i cant find anyone with the exact same symptoms. Ive found some with similar noises and most say its either rear hub bearings or CSB.
    I have a feeling my noise is from bad diff bearings.
    So once i get going up about 30 and anything above that i get a lot of rotational noise. Sounds similar to loud tires but i dont believe its the tires. Sound is there on power and off, in gear and out. I can feel a bit of vibration possibly from the tunnel. My CSB is only a few years old (i havent checked my DS ujoints yet).
    Under a hard turn under power (3rd gear pull on a nice off ramp or something) i will get a vibration and corresponding low pitch sound.
    Diff is an open 373 with >200k miles on it.
    CSB is a couple years old, as is the guibo.
    one of the rear hub bearings is about 4 years old, the other is unknown.
  • NC325iC
    • Mar 2004
    • 6565
    i think im gonna try to find a good low mile maybe replacement diff, then see if i need to do anything else.
